FM Transmitter Using Logic Gates (English), FM Transmitter Using Logic Gates
Source: InternetPublisher:jikai233 Keywords: Wireless communication FM microphone NOT gate circuit Updated: 2020/02/19
This is a FM Transmitter circuit. This circuit uses logic gates. This transmitter circuit has a RF oscillator. This oscillator uses 10.7Mhz ceramic filter and inverter N2 to drive the parallel combination of N4 to N6 through N3. Here is the circuit:
The output impedance will be low because these inverters are in parallel, so an aerial of 1/4h wavelength can be driven directly. There would be a lot of harmonics in the output of N4-N6 because the output of N4 to N6 is square wave. The 9th harmonics of 10.7Mhz (96.3Mhz) will hence be at the center of the FM band. As an audio amplifier, this circuit uses N1. It will amplify audio signals from the microphone and fed it to varycap diode. The capacitance of the varycap is varied by the signal that will vary the oscillator frequency that produce Frequency Modulation.
- Production of a FM wireless microphone
- Using 3DA87C to make FM transmitter circuit
- Homemade wireless voice transmitter for telephone
- RX3408 FM/FSK 500~20 MHz Receiver
- GPS RF front-end circuit composed of MX2740
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- TR5100 FM 150~15 MHz transceiver
- CYWUSB6932 GFSK 2.4 GHz Wireless USB Interface Transmitter
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- Stereo FM transmitter circuit designed with BH1417
- Circuit diagram of triode inverter
- 2-tube FM microphone with 3V power supply
- CC4528 dual monostable flip-flop design multivibrator circuit diagram
- Various waveform signal generators
- Single tube TV antenna amplifier circuit
- Sample/hold (S/H) circuit diagram
- Frequency modulation (fm) waveform generator circuit diagram
- Low frequency equivalent circuit schematic diagram
- Keyed oscillator circuit diagram designed by CC4528
- Infrared communication circuit diagram based on microcontroller
