Color TV video amplifier circuit designed by TDA6101
Source: InternetPublisher:张三叔 Keywords: Video circuit tda6101 color TV video amplifier circuit Updated: 2020/02/14
![Color TV amplifier circuit designed by TDA6101](http://www.eeworld.com.cn/circuit/upload/cdbdb8bfd5819dcf15f66e8c3deef163/dbaa3306202c1c01520d1afe196caf8a.png)
TDA6101 is a broadband video amplification circuit with a video bandwidth of 9MHz and is generally used in higher-end models.
Pin 1: 2.7V - reference voltage
Pin 2: 12V - power supply
Pin 3: 2.6V——signal input terminal
Pin 4: 0V - ground
Pin 5: 6.7V - dark current signal output
Pin 6: 200V - power supply
Pin 7: 130V - AC signal output
Pin 8: 130V - DC signal output
Pin 9: 130V - feedback output
- A high-quality tube amplifier with 6P3P design
- Single-ended Class A amplifier using gallstone composite tube design
- Design and production of class AB headphone amplifier
- LM4766 Dual 40W+40W Power Amplifier
- A simple and practical tube amplifier
- LM4820-6 audio power amplifier circuit
- Tube single-ended class A 300B power amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- Horseshoe gallbladder preamplifier circuit
- Active power amplifier circuit composed of TDA2003
- Uncommonly used homemade home TV circuit diagram
- Application of CCD image sensor in low-light TV system
- Color TV amplifier discrete component application circuit
- TDA6107 color TV amplifier application circuit
- Color TV video amplifier circuit designed by TDA6101
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
