Capacitive sensor system circuit
Source: InternetPublisher:toothache Keywords: Sensors reflectors power supplies and other power circuits Updated: 2021/03/07
![200962423917801.JPG](http://www.eeworld.com.cn/circuit/upload/0a84fe09cb4a2c266f7127fb74485089/a40d01111d6a8ca20107131127ba4e5e.jpg)
This circuit diagram shows the electric field configuration of a capacitive proximity sensor in the form of a capacitive reflector. It consists of a sensing electrode driven by an AC voltage, creating an electric field near the electrode. Material entering this electric field will be induced by the magnetic field on the resistor between the sensing electrode and electrical ground.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- What kind of circuit is a voltage regulator circuit?
- ISO113 circuit that can reduce power consumption
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Parallel DC regulated power supply circuit diagram
- Current/voltage conversion circuit using current converter
- Adjustable regulated power supply with current limiting protection
- USB power socket using the car battery
- Design of electric vehicle charger
- High-resolution 35 mm CCD image sensor, did you know?
- Do you know about the X-Class platform and XGS 8000/XGS 12000 image sensor?
- Contact switch or proximity sensor circuit
- Ultrasonic proximity sensor circuit
- Circuit diagram of a thermocouple cold junction temperature compensation
- voltage amplifier circuit
- Sensor bridge circuit diagram
- Basic connection diagram of bridge sensor and XTR104 02
- Bridge sensor transmit/receive circuit (with isolated output)
- Sensor analog signal input ADC701/SHC702 circuit
