How will ITECH DC power be applied in AI?
Source: InternetPublisher:JFET Keywords: DC power supply Updated: 2021/05/24
Generally speaking, the working environment requirements of intelligent inspection robots and intelligent sorting robots are very stringent, and for the power supply that provides these signals to IC chips, high speed and high precision are often essential factors.
Requirement 1: Test of static current
Under a certain voltage, let the IC be in a no-load, non-oscillation state. Connect one end of the ammeter to the positive pole of the power supply and the other end to the VDD pin of the IC. The ammeter reading is the quiescent current of the IC.
Test picture one
Requirement 2: Testing of driving current
Under a certain voltage, replace the load of the IC with an adjustable resistor to allow the IC to work normally. When there is output at the output port, adjust the resistance of the adjustable resistor so that the level of the IC output meets the test requirements.
Test picture two
For the above test requirements, according to the voltage specification requirements and accuracy requirements, suitable DC power supplies are recommended, such as IT6400 bipolar power supply; IT6100 high-speed and high-precision power supply; among them, the IT6400 bipolar power supply has an accuracy as high as na level, which is both a power supply and a Quiescent current can be tested.
To sum up: IC chip testing is often inseparable from a high-precision and high-speed power supply. As the world's leading provider of power supply testing solutions, ITECH plays an important role in the performance testing of robots' internal energy supply systems and power devices. Whether it is used as an enabling power supply to test robot sensor circuits or IC chip components, or the ITS9500 power supply test system tests the power supply conditions of robot power circuits, or it meets the testing requirements of various power levels, ITECH can rely on it. High-quality and high-precision testing solutions protect engineers' R&D and production, truly realizing "China made".
- 220V Remote Load Monitor
- Fabrication of multi-cell lithium battery charging circuit
- Recommended circuits for different power on times of LM4911
- Basic connection circuit of signal and power supply composed of ISOll3
- Voltage-current converter constructed with XTR110
- A simple positive and negative power supply circuit
- Power supply circuit that can reduce LM317 ripple
- Car Audio Power Supply
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- Power circuit of STR5412
- Laser power circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Transistor stabilized current power supply circuit 2
- Additional power circuit design for USB devices
- Class A power amplifier power circuit
- Household emergency power circuit
- 5V uninterruptible power supply circuit
- CTX-C2 dual-band high-resolution color display power circuit
- COMPAQ 420G type SVGA color display power supply circuit
