Delay pull-in relay switch control circuit diagram
Source: InternetPublisher:supremeOne Keywords: Power supplyAC/DC Updated: 2020/10/10
This article introduces a delay pull-in relay switch control circuit diagram. As shown in the figure below, after the power is turned on, the time flow begins with the capacitor C discharging first and then charging through the 20M slave point resistor.
![Delay pull-in relay switch control circuit diagram](http://www.eeworld.com.cn/circuit/upload/4c0c4190275249244e4f589d7c2272f9/9c2702fc56a94dd668f816bc8bca91ab.jpg)
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Using Lead-acid Battery as Power Source for Walkman
- Fabrication of multi-cell lithium battery charging circuit
- Single-power supply circuit for ISO122P/ISO124
- A simple positive and negative power supply circuit
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- MIC4680 constant current charger
- Mc34063 MP3 Switching Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Principle of single live wire power taking circuit
- Sense amplifier circuit
- Two-wire remote AC electronic thermostat (gas or oil furnace control)
- Three-phase phase loss alarm light circuit
- Power circuit of STR5412
- Interface circuit diagram for controlling AC load
- 3v to 5v circuit diagram
- Power circuit of LBO-522 dual trace oscilloscope
- Timing switch AC power circuit
- Recording level power supply circuit
