A delayed pull-in relay circuit diagram
Source: InternetPublisher:国民男神经 Keywords: Power supply other power circuits Updated: 2021/12/29
If you want to obtain a long-term and easily adjustable delay circuit, the relay current should be controlled by a transistor, and an RC link should be connected to the base circuit, as shown in the figure. If the power supply voltage, capacitance C, current amplification coefficient β and the required pull-in power are all known, the appropriate relay coil resistance value and operating voltage value should be selected to make the delay time as large as possible. This time can be obtained by The time constant value is determined. As shown below:
![A delayed pull-in relay circuit diagram](http://www.eeworld.com.cn/circuit/upload/bf8c3a716e2b88f93e6a770d7495c9db/37a329c0cbabed7e5785f84e6650589b.jpg)
- Energy-saving motorcycle rectifier regulator
- What kind of circuit is a voltage regulator circuit?
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Simple and practical LED lamp driving circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Homemade low-power UPS
- CNC regulated power supply production
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
