Bidirectional thyristor AC voltage regulator circuit controlled by resistor-capacitor phase-shift trigger circuit
Source: InternetPublisher:无人共我 Keywords: circuit diagram thyristor AC Updated: 2021/07/22
This circuit is only suitable for resistive loads. Some people use it to drive a 220V AC fan, which will actually cause the fan to make abnormal noise and possibly burn out the motor. You should use another voltage regulating circuit with a fan.
- An article explains the working principle of the Wheatstone bridge
- How does sand become chips?
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Ceramic filter structure/working principle/characteristics/application
- Make a flameless electronic candle using simple electronics and LEDs
- What types of force sensors are there?
- What is the difference between JFET and MOSFET
- What is a Demultiplexer
- Star finder battery indicator circuit
- LED lights that “drain” battery power
- Detection circuit diagram of AC side voltage Us based on SG3525
- Capacitor step-down LED drive circuit diagram using thyristor
- Zero-crossing trigger circuit diagram based on thyristor
- Light controlled lighting using one-way thyristor
- Triac two-tone dimmer (1)
- SCR control buzzer circuit
- Inductive automatic hand dryer circuit
- Series thyristor flasher that can be connected to various loads
- Touch type thyristor zero-crossing switch circuit diagram
- Bidirectional thyristor AC voltage regulator circuit controlled by resistor-capacitor phase-shift trigger circuit
