Ringing signal detection circuit
Source: InternetPublisher:张三叔 Keywords: Ringing signal detection circuit photocoupler light emitting diode Updated: 2020/08/17
Shown is the ringing signal detection circuit , which is composed of photoelectric coupler PT1. It is composed of bidirectional diode VA1, diodes D4, Ds, ZD1,
Rll and R13. This circuit is also connected in parallel with the telephone. When the ringing signal is transmitted, it passes through the half-wave rectification circuit composed of D4 and D5. During
the rectification cycle of D4, the PT1 light-emitting diode is turned on, and the corresponding phototransistor is also turned on. After being inverted by the driver IC3, it outputs a low level. , thereby
forming a CI (call indication) signal, indicating that there is a ringing call signal on the line.
- What is a photocoupler and how to select and use one?
- In-depth analysis of energy losses in oscillation frequencies
- What are the parts of the fpga design process
- Transfer characteristics of BJT, how to apply Shockley equation?
- Working principle and truth table of JK flip-flop
- DIY a decorative lamp
- How does RCCB work?
- How to build a triangle wave generator using an op amp and discrete components
- How to install the accelerometer
- Star finder battery indicator circuit
- Ward call device circuit diagram
- Light emitting diode (LED) display driver circuit
- Asynchronous motor protection circuit composed of photoelectric coupler
- LED lighting display detection circuit with overload protection
- Interface circuit c for automatic counting with electronic counter
- Mains undervoltage and overvoltage protection circuit 5
- One of the mains undervoltage and overvoltage alarm circuits
- Fuse blown sound and light alarm circuit 3
- FT-1R optical signal detection circuit diagram using MCT
- 4N22A to 4N24A type photocoupler circuit
