Motor electronic speed regulation circuit
Source: InternetPublisher:小胖友 Keywords: Power switch voltage regulator Updated: 2020/02/19
![Motor electronic speed regulation circuit](http://www.eeworld.com.cn/circuit/upload/c00c96d02dfa8c67b85ffd46fd3d903a/01795e5ca58939c11fc5242207d6b4d0.jpg)
This circuit is simple and easy to make, and can be used to control the speed of small single-phase AC motors.
After the 220V AC voltage is stepped down by C3, rectified by VD3, filtered by C1 and stabilized by VS, it provides +12V DC working voltage for the IC. After the ultra-low frequency oscillator is powered on, it outputs an ultra-low frequency pulse signal with a frequency of about 1Hz from pin 3 of the IC. This pulse signal is added to the control end (positive end) of the solid-state relay KN, and the VTH is controlled by controlling the on and off of KN (when the pulse signal is a positive pulse, KN is on; when the pulse signal is a negative pulse, KN is off) conduction angle.
Adjusting the resistance of RP can change the duty cycle of the IC's pin 3 output pulse signal. The greater the duty cycle of the pulse signal, the longer the conduction time of VTH per unit time, the higher the operating voltage of the motor M and the faster the operating speed.
- Sharing layout and tips for multi-rail power supply design
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- In-depth analysis of DC-AC converter inverter
- Introduction and principle analysis of switching regulated power supply
- Recommended circuits for different power on times of LM4911
- The production of adjustable voltage-stabilized power supply composed of LM317
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- Detailed explanation of mobile phone charger circuit diagram
- STR5412 power circuit
- Power circuit of STR5412
- Industrial X-ray flaw detector delay control switch circuit diagram
- Fixed and switching hybrid regulated power supply electronic circuit diagram
- Schematic diagram of a sound and light dual control energy-saving switch circuit
- DC 12V to AC 100V inverter power supply circuit design
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Class A power amplifier power circuit
- Antenna amplifier synchronous power supply circuit
