Electronic regulator basic circuit
Source: InternetPublisher:supremeOne Keywords: Power battery circuit Updated: 2020/05/28
![Electronic regulator basic circuit](http://www.eeworld.com.cn/circuit/upload/80a6e776082301d7536902bed0c229c2/dc90f6e2d0552b61b55b324e3cba7904.jpg)
Working principle: ① When the ignition switch SW is just turned on, the engine does not rotate, the generator does not generate electricity, and the battery voltage is added to the voltage divider R1 and R2. At this time, the reverse breakdown of the voltage regulator tube VS cannot be caused because UR1 is low. , VT1 is cut off, and VT1 is cut off so that VT2 is turned on, and the generator magnetic field circuit is turned on. At this time, the battery supplies the magnetic field current. As the engine starts, the generator speed increases, the generator is separately excited to generate electricity, and the voltage increases.
② When the generator voltage rises to greater than the battery voltage, the generator is self-excited to generate electricity and begins to charge the external battery. If the generator output voltage UB < the regulator adjustment upper limit UB2 at this time, VT1 continues to cut off and VT2 continues to conduct, but this time The magnetic field current is supplied by the generator, and the generator voltage increases rapidly as the rotational speed increases.
③ When the generator voltage rises to equal to the upper limit of regulation UB2, the regulator begins to adjust the voltage. At this time, VS is on, VT1 is on, and VT2 is off. The generator magnetic field circuit is cut off. Because the magnetic field is cut off, the magnetic flux decreases and the generator output voltage decreases.
- Analysis of the working principle of switching regulator
- Op amp power supply decoupling bypass measures
- Driving circuit that controls LED brightness using PWM signal
- The constant current source composed of two transistors can drive high power
- LED rechargeable flashlight circuit diagram
- Low cost and high performance LED constant current power supply
- Voltage-current converter constructed with XTR110
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Circuit diagram explanation: simple switching power supply circuit diagram
- MAX1555 reference design circuit | battery charger application circuit
- Design of adjustable DC stabilized power supply circuit module
- Power circuit of STR5412
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Warm current power supply circuit b
- Timing switch AC power circuit
- Recording level power supply circuit
- Super Class A power amplifier power circuit
- Practical neon light power circuit
