Digital tube lighting circuit
Source: InternetPublisher:柯南道尔 Keywords: Digital tube 74LS245 Updated: 2020/12/06
![Digital tube lighting circuit](http://www.eeworld.com.cn/circuit/upload/2bbef0f5ad4bd7767767b2998a23d02b/d98d2b9be7b14a92ca33322c28a99a47.jpg)
After the microcontroller executes the program, the Pl port outputs to the input end of the bidirectional driver chip 74LS245 , which drives each segment of the digital tube in phase. According to the information output from the Pl port, characters are formed on the digital tube to achieve the purpose of using the digital tube to display characters.
The Pl port is connected to the input terminal of 74LS245, and its output terminal is directly connected to each segment of the digital tube. Among them, pin 19 of 74LS245 is called the enable control terminal. When this pin is at low level , 74LS245 transmits data, so pin 19 is connected to the ground wire. Pin 1 is the transmission direction control terminal. When the pin is high level, pins 2 to 9 are the input terminals, and pins 1 8 to 1 1 are the corresponding output terminals. When pin 1 is low level, pins 18 to 1 1 are the input terminals. is the input terminal, and pins 2 to 9 are the corresponding output terminals. In this example, pin 1 of the circuit is connected to low level , and the latter is used for input and output. The common cathode end of the digital tube is connected to the ground wire. This connection method is called static mode.
- In-depth analysis of DC-AC converter inverter
- Introduction and principle analysis of switching regulated power supply
- ISO113 circuit that can reduce power consumption
- Recommended circuits for different power on times of LM4911
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- CNC regulated power supply production
- Electric bicycle battery charger circuit
- Production of backup power supply for cordless phone
- LM317T voltage regulation adjustable circuit diagram explanation
- Excellent performance household inverter power supply circuit
- Dual adjustable power circuit
- Power circuit of LBO-522 dual trace oscilloscope
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Single phase thyristor slotless nickel plated power circuit
- Music power circuit
- Wide input 350mA LED driver circuit based on NCL30000
- Common power circuits and applications 09
