Refrigerator working indicator light circuit
Source: InternetPublisher:走马观花 Updated: 2015/04/01
Installing a working indicator light on the power socket of the refrigerator not only makes it easier to observe the start and stop of the refrigerator, but also increases the aesthetics of the socket. See Figure 1 for the circuit. The induced current on the secondary side of the current transformer is used to light up the light-emitting diode. For the current transformer, you can find a slightly larger transistor radio input or output transformer and modify it according to the data shown in the figure. Pay attention to the insulation between windings. The current limiting resistor R can range from several ohms to several
![冰箱工作指示灯电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/63d197c0-3c63-11ec-a413-086126841eb8.gif)
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to set up a cheap beam break sensor control distance scene using a reflector
- Squirrel cage asynchronous motor reverse braking control circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and analysis of wire control circuit
- An experimental model of an infrared radio alarm
- Homemade short circuit alarm device
- Water supply reminder after water outage
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
