70-watt switching power supply integrated circuit diagram based on KA2S0880
Source: InternetPublisher:supremeOne Keywords: switching power supply circuit diagram integrated circuit PLUSMN Updated: 2020/09/30
The schematic shows a 70W stereo amplifier power converter that is built on a chip KA2S0880, which includes all the necessary components to build the main power supply capabilities of the power supply. The chip is very stable in operation and has all necessary protections.
Features:
Input voltage: 220 - 240 V AC
Output voltage (no load): ± 16,5 V
Full load: ± 15 V... . ± 15.5 V
long-term maximum power output, it is a chip in the world: 70W
Operating frequency: 20kHz
Power efficiency: 90...93%
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- A very convenient small power supply circuit to share
- What kind of circuit is a voltage regulator circuit?
- ISO113 circuit that can reduce power consumption
- Single-power supply circuit for ISO122P/ISO124
- Op amp power supply decoupling bypass measures
- The constant current source composed of two transistors can drive high power
- USB power socket using the car battery
- Car Audio Power Supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- What is a freewheeling diode?
- Layout and design principles of switching power supply
- Self-switching power supply
- 220V/12V 150W switching power supply circuit diagram
- Adjustable regulated power supply circuit with saturable reactor
- uPC1342V internal circuit principle
- Application circuit of TDA2040(A)-dual power supply operation
- Application circuit of TDA2030A - dual power supply BTL operation
- High performance DC power amplifier drive circuit AP500A-02
- ±18V regulated power supply circuit
