Single and Quad Channel Linear EML Driver Series, Did You Know?
Source: InternetPublisher:兰博 Keywords: Single channel four channel eml driver Updated: 2021/11/29
What is a family of single and quad linear EML drivers? What does it do? MACOM’s new MAOM-005311 and MAOM-005411 are single and quad 53Gbaud EML drivers with 1.8Vpp output
Devices provide the ultra-low power and high bandwidth required to support 100G single lambda modules
Small surface mount package supports 100G and 400G DR and FR modules
Lowell, MA, March 14, 2018 – MACOM Technology Solutions Inc. (“MACOM”) today announced the MAOM-005311, a single- and quad-channel linear externally modulated laser (EML) driver for 53 Gbaud PAM-4 applications. and MAOM-005411. This family of surface mount drivers delivers the low power consumption and high bandwidth required for 100 Gbps per wave for 100G/400G data center applications.
As demand for lower cost-per-bit module solutions continues to grow, with the ability to send 100Gbps on a single wavelength using PAM-4 modulation at 53Gbaud, module suppliers can significantly reduce costs by reducing the number of optical components by a factor of four. . MACOM's EML driver family is the first-to-market solution of its kind, leveraging innovative designs and advanced semiconductor and packaging technologies to provide customers with the best high-performance integrated solutions.
“MACOM’s 53G EML drivers have delivered outstanding performance to date,” said Ray Moroney, Vice President and Business Line Manager, Networking Division, MACOM Corporation. “We believe these devices, combined with the MATA-005817 and MATA-003819 TIAs, will be the key to achieving The key to applying new generation PAM-4 optical connectivity in data centers.”
MACOM's MAOM-005311 and MAOM-005411 feature differential inputs to provide common-mode rejection, while the single-ended output voltage is adjustable to 1.8Vpp. These devices provide a 6 dB gain control range and integrate peak detectors on each channel for closed-loop control. The solution comes in a surface mount package with integrated high frequency chokes and coupling capacitors to bias the driver and EML. The above is the analysis of single-channel and four-channel linear EML driver series. I hope it can help you.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Introduction and principle analysis of switching regulated power supply
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Constant current LED lamp driver circuit with soft start and anti-shock
- Switching power supply circuit composition and function introduction of each part
- Integrated regulated power supply with continuously adjustable output voltage
- The production of adjustable voltage-stabilized power supply composed of LM317
- Single and Quad Channel Linear EML Driver Series, Did You Know?
- Design of adjustable DC stabilized power supply circuit module
- Power supply circuit design optimized for digital light projectors
- Industrial product promotion and shopping guide DC power supply circuit
- EPSON PHOTO 830U printer power circuit
- Power circuit with smoothing filter capacitor
- Output 12V-10A power supply circuit
- Warm current power supply circuit b
- Four-channel remote control switch circuit b
- Common power circuits and applications 05
