Soil moisture meter circuit diagram
Source: InternetPublisher:aytwartoofyoroo Keywords: moisture measurement soil moisture Updated: 2020/12/14
This circuit consists of VT1, VT2, capacitors C2, C3, resistors R1, R2, R3, R4, etc., which together form an oscillation circuit. The oscillation frequency is controlled by R6. One end of R6 is connected to a lead of the probe, and the probe is inserted into the soil. As the soil moisture changes, the resistance value on the probe also changes significantly. When this change is transmitted to R6, it will change the oscillation frequency of the oscillation circuit. The frequency change can be displayed through the swing of the ammeter connected to the collector of VT2, and people can judge the humidity based on the swing scale of this meter needle.
- What is a photocoupler and how to select and use one?
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Types and structures/characteristics/functions/implementations of smart sensors
- FPGA Features and Architecture
- Transfer characteristics of BJT, how to apply Shockley equation?
- How to calculate the value of capacitors in parallel?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- LED Night Light
- An example of proportional integral circuit diagram
- Soil moisture meter circuit diagram
- Machine-made tile humidity measurement circuit
- Air humidity measurement circuit 2
- One of the air humidity measurement circuits
- Air humidity measuring instrument circuit
- Grain moisture meter
- air humidity meter
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
