Home >
Control Circuits >Motor Control > Single-phase motor auto-coupling main winding step-down speed regulating circuit
Source: InternetPublisher:公子李 Updated: 2010/01/15
As shown in the figure, the voltage reduction characteristic of the autotransformer is used to directly reduce the voltage of the main winding LR to achieve the purpose of voltage reduction and speed regulation of the single-phase motor. TA is an autotransformer, and I, II, and III are gears. Since gear III has the highest voltage reduction of TA, when SA is moved to gear III, the speed is the lowest. LA is the auxiliary winding and LR is the main winding.
Latest Control Circuits Circuits
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Motor control circuit for starting and running without phase loss
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of wire control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Do-it-yourself trial production of phase failure protection device
- Water supply reminder after water outage
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
