Home >
Control Circuits >Motor Control > Use the light to check the three-phase motor winding for broken wires
Source: InternetPublisher:抄写员 Updated: 2018/10/21
If one phase in the stator winding of a three-phase motor is circuit-opened, a phase loss will occur inside the motor. For a three-phase motor with star (Y) connection, the consequences of internal phase loss and power supply phase loss are exactly the same. For motors with delta (△) connection, when one phase winding is disconnected, an open triangle is formed inside the three-phase motor. There is no current in the disconnected phase winding, and the currents in the other two phases are increased than normal values. Usually, three-phase motor open circuit faults mostly occur at the ends of the windings, or at the terminals of each winding component, or at the ends of the three-phase lead wires. These areas should be checked first during inspection. To check the open circuit of a small three-phase motor, you can use the R×1Ω block of a multimeter to measure it, or you can use a light to detect it. The method is as shown in the figure. The so-called "light" is composed of one electric bead, two large batteries (3V), and a pair of test leads. If the winding is normal, the bead H will light up; if the winding is disconnected, H will not light up.
Latest Control Circuits Circuits
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Analysis of the working principle of car garage door lights
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Squirrel cage asynchronous motor reverse braking control circuit
- Using P110C to control 6 DC motors simultaneously
- Light-controlled circuit design and analysis
- Delay switch made with LM431
- Homemade short circuit alarm device
- Simple disconnection burglar alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
