Home >
Control Circuits >Motor Control > Calibrating current transformer circuit using portable lamp transformer
Source: InternetPublisher:傻阿乐 Updated: 2015/12/24
Whether the 10% error of the current transformer is qualified or not has a direct impact on the relay protection in the power system. If it is not qualified, it will cause the current protection to refuse to operate, which will cause the accident to expand, so it must be calibrated regularly. The method of calibrating the current transformer using a portable lamp transformer is as shown in the figure. Operation method: close the knife switch QS, slowly adjust the voltage regulator TA, the voltage of the street light transformer T gradually rises, and the readings of the ammeters PA1 and PA2 slowly increase. When the reading of PA2 increases to the action value I of current relay KA1, read the value I1 of ammeter PA1. If the error can meet the following formula:
It means that the current transformer TA1 is not saturated, it is qualified. Otherwise, replace the current transformer and re-inspect it. The verification is that the current transformers on L1, L2 and L3 must not be live, that is, when the power supply is out.
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- Use your smartphone to turn on/off the power in your home
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to make a wheeled self-balancing robot using ultrasonic sensors
- DC motor drive circuit composed of L293D
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Magnetic door and window anti-theft alarm
- Night dog barking anti-theft reminder circuit
- Password type motorcycle anti-theft device
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
