Automotive power converter circuit design
Source: InternetPublisher:aytwartoofyoroo Keywords: Power switch voltage regulator power converter Updated: 2021/09/01
Circuit principle: The 12V power supply is taken out from the car cigarette lighter jack and sent to the input pin of the adjustable three-terminal voltage regulator LM317 through SW1A, one of the two-pole six-bit band switches. The adjustment pin (ADJ) of LM317 is connected to different voltages through SW1B. resistor to the negative terminal of the power supply. When SW1 is in different gears, several voltages of 1.5V, 3.0V, 5.0V, 6.0V, 9.0V, and 12V can be obtained at the output end for use by corresponding low-voltage electrical appliances. LM317 should be installed on an aluminum heat sink (100×100×25mm), mainly because it generates more heat at the 1.5V level. The entire circuit is put into a suitable small box, and only the band switch is provided on the panel.
R2~R6 in the figure are the output voltage setting resistors. If other levels of voltage are required, they can be calculated as follows:
VOUT=(1+R2/R1)VREF+IADJ≌(1+R2/R1)VREF where VREF is the reference voltage, typical value is 1.25V, IADJ is the current flowing out of ADJ pin, typical value is 50μA, R2 represents R2~ in the figure One of R6. In the figure, C1 and C2 are anti-vibration capacitors, C3 can improve the ripple removal rate and circuit stability, D1 is the output short-circuit protection diode, and D2 prevents damage to the voltage regulator when the output terminal has a higher potential than the input terminal. The cigarette lighter jack in the car can only obtain 12V voltage, but CDs, LCD TVs, MP3s, game consoles, etc. require different power supply voltages.
- A very convenient small power supply circuit to share
- Benefits of Wide Bandgap Technology for Power Converters
- 220V Remote Load Monitor
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic circuit description of adjustable voltage regulator LM317
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Miniature polarity reversal power supply using MAX1721
- Voltage-current converter constructed with XTR110
- A simple positive and negative power supply circuit
- Homemade home inverter circuit diagram
- LTM8045 SEPIC regulator application circuit diagram collection
- Series switching power supply output voltage filter circuit
- Voltage stabilization circuit diagram with synchronous adjustment of positive and negative voltages
- Two-way power supply system automatic conversion power supply system circuit diagram
- STR5412 power circuit
- Circuit design of automatic street light controller using power switch TWH875
- Power circuit a composed of intelligent thyristor modules
- Karaoke light controller circuit (1)
- Head amplifier dedicated power supply circuit
- DC power supply circuit for semiconductor radio
