Hitachi CMT2988 pillow calibration circuit
Source: InternetPublisher:天天都吃好吃的 Updated: 2011/03/09
The same models as Hitachi CMT2988 pillow calibration circuit include: Hitachi 25M8C, CMT2518, CMT2718, CMT2916, CMT2588, CMT2598, CMT2998, Furi HFC2581, 2586, 2587, 2986, 2987, etc.
The sawtooth wave voltage of about 4V (peak-to-peak value) at both ends of R617 is added to pin (1) of IC651 through C651 and R651. After its internal amplification and integration processing, a voltage of about 2V (peak-to-peak value) is output from pin (2). The concave parabolic wave voltage is integrated by C653, C652, and R666. The amplitude of the parabolic wave is adjusted by R657, and then added to pin (7) of IC651 via C655. After internal amplification and shaping, it is output from pin (8). After the convex parabolic voltage is followed by the Q652 emitter and reversely amplified by Q651, a concave parabolic voltage of about 9V (peak-to-peak value) is formed at both ends of C727, which is sent to the horizontal deflection coil through L703, and the horizontal deflection current is Modulation, corrected for pincushion distortion.
R655 is the line width adjustment potentiometer, and R657 is the pillow adjustment potentiometer.
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- In-depth analysis of energy losses in oscillation frequencies
- Types and structures/characteristics/functions/implementations of smart sensors
- What is the difference between CPLD and FPGA?
- How to calculate the value of capacitors in parallel?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Basic characteristics/working principles and application circuits of tunnel diodes
- Important things to know about PCB routing and how to design the right routing for your PCB
- Star finder battery indicator circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
