Dynamic Audio Preamplifier
Source: InternetPublisher:狂妄火龙果 Updated: 2011/12/27
This is a 3 stage discrete amplifier with gain control. Alternative transistors such as BC109C, BC548, BC549, BC549C may be used with little change in performance. The first stage built around Q1 operates in common base configuration. This is unusuable in audio stages, but in this case, it allows Q1 to operate at low noise levels and improves overall signal to noise ratio. Q2 and Q3 form a direct coupled amplifier, similar to my earlier mic preamp.
Input and Output Impedance:
As the signal from a dynamic microphone is low typically much less than 10mV, then there is little to be gained by setting the collector voltage voltage of Q1 to half the supply voltage. In power amplifiers, biasing to half the supply voltage allows for maximum voltage swing, and highest overload margin, but where input levels are low, any value in the linear part of the operating characteristics will suffice. Here Q1 operates with a collector voltage of 2.4V and a low collector current of around 200uA. This low collector current ensures low noise performance and also raises the input impedance of the stage to around 400 ohms. This is a good match for any dynamic microphone having an impedances between 200 and 600 ohms.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Signal diode arrays/configurations, freewheeling diode operation
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Analysis of the basic principle of measuring resistance by bridge method
- How does sand become chips?
- Causes and solutions for noise in digital Class D amplifiers
- RC filter explained in detail
- What are the parts of the fpga design process
- Datasheet/Pinout/Technical Specifications of LMC555
- Diode-based clipping circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
