Circuit design of automatic street light controller using power switch TWH875
Source: InternetPublisher:萌面大虾 Keywords: Power DC/DC Updated: 2021/07/30
Circuit working principle: The light-controlled street light circuit consists of a power supply circuit and a light-controlled circuit, as shown in the figure. The power circuit is composed of power transformer T, rectifier diodes VDl-VD4 and filter capacitor C. The light control circuit consists of photoresistor RG, resistors R1, R2, variable resistor RP, electronic switch integrated circuit IC, relay K and diode VD5. After the AC 220V voltage is stepped down by T, rectified by VD1-VD4 and filtered by C, it provides +12V working power for the light control circuit. During the day, RG is exposed to light and becomes in a low-resistance state, causing the IC's pin 2 (strobe terminal) and pin 4 (output terminal) to be at high level. Its internal electronic switch is in a cut-off state, K does not pull in, and the street light EL not bright. At night, when there is no light, the RC is in a high-resistance state. Pin 2 of the IC becomes low level, the internal electronic switch is turned on, and the EL lights up. Adjusting the resistance of RP can change the sensitivity of the light control.
![Circuit design of automatic street light controller using power switch TWH875](http://www.eeworld.com.cn/circuit/upload/797f4dc144ef4446deffd4713653998f/1399faeaf9f9dbe597faadf5918c1410.jpg)
=Rl and R2 use 1/4W metal film resistors or carbon film resistors. RP uses solid variable resistors. RG uses RG45 series photoresistors. C selects an aluminum electrolytic capacitor with a withstand voltage of 16V. VDl-VD5 use 1N400l or lN4007 silicon rectifier diodes. The IC uses the TWH8751 electronic switch integrated circuit. K selects JZX-22F type (contact current load is IOA) l2V DC relay, and its two sets of normally open contacts can be used in parallel. T selects a power transformer of 3-5W and a secondary voltage of l2V. You can make your own printed circuit board during production, or you can use a universal printed circuit board. After the circuit is installed, as long as the wiring is correct, it can generally be used normally without debugging.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- MAX1811 Lithium Battery Charger Production
- Importance of Voltage Supervisors and Output Topology Selection
- DC output DC converter circuit
- Clock switching circuit and its precautions
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit of STR5412
- Signal simulator circuit diagram
- Dual-purpose voice-activated switch circuit diagram
- Three-way DC-DC converter circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
