Application of field effect transistors in pocket radio circuits
Source: InternetPublisher:走马观花 Keywords: Field effect transistor radio circuit BSP resonant circuit Updated: 2020/06/06
(1) Application of field effect transistor fixed bias circuit in double-tube pocket radio circuit
The picture shown is an ultra-small radio circuit that uses two transistors. This circuit has high sensitivity. In this circuit,
the battery acts as a DC power supply to provide a bias voltage to the drain of the FET through the load resistor R1, making it work in an amplified state.
Various signals in the sky are received by an external antenna , and the AC signals pass through cl and enter the LC resonant circuit . The LC resonant circuit is composed of a magnetic bar coil and a capacitor
. After frequency selection of the resonant circuit , it is coupled to the grid of the Yang effect transistor VR via C4, superimposed with the negative bias of the grid edge, and added to the grid of the FET to make
the field effect The drain current ID of the tube changes accordingly, and a voltage drop occurs on the load resistor RI. After being isolated from DC by c5, it is output, and
the amplified signal voltage is obtained at the output end. The amplified signal is sent to the base of the transistor, which amplifies and outputs a purer audio signal
to the headphones.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- Analysis of the flow direction of transistor current
- What does a rectifier do? What is the process of rectification?
- What is the difference between CPLD and FPGA?
- Datasheet/Pinout/Technical Specifications of LMC555
- Basic characteristics/working principles and application circuits of tunnel diodes
- Causes of PCB deformation How to prevent circuit board bending and warping
- Summary of knowledge points of multiplexer
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Motor overcurrent protection circuit
- electromagnetic field sensor
- Ultrasonic blind pathfinder circuit
- Smoking Cessation Circuit
- Crop anti-frost circuit
- Egg heating control circuit
- Diode Balanced Mixer Circuit
- Varactor Diode Frequency Modulator
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
