Bridge Measurement - 0 to 5V Voltage Isolated Output Circuit
Source: InternetPublisher:方世玉223 Keywords: Output circuit isolated output Updated: 2021/03/09
When the distance between the RTD temperature sensor and the amplifier is relatively long,
issues such as the sensor's lead resistance and the vulnerability of the leads to interference cannot be ignored. The circuit shown in Figure 1 can solve this problem.
This circuit uses a voltage-4-20mA current converter XTR103. XTR103 is a dedicated signal processing circuit for RTD.
It integrates Rrl'D linearization circuit internally and expands the power supply voltage range to +9~+40V.
XTR103 outputs two 0.8mA current sources. The current sources are driven by VT2 and then added to the RTD to avoid
attenuation caused by the line and suppress line interference. The function of Rh is similar to that of R in XTR101. The function is exactly the same: limiting
the maximum value of the output current. Rini is a linear adjustment resistor, which can change the resistance value to change the linearity. The output signal
gets a current of 4~20mA after being connected to the external transistor VT1. RCV420 is a 4-20mA current- to-voltage dedicated converter (will be introduced in "3" of this section ), which outputs a 0~5V voltage
after conversion.
But the isolation output amplifier IS0122 is added . Regarding the isolation
amplifier ISOIOO series,
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What is the difference between CPLD and FPGA?
- How to calculate the value of capacitors in parallel?
- Causes of PCB deformation How to prevent circuit board bending and warping
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Build a musical fountain using Arduino and sound sensor
- Star finder battery indicator circuit
- Bridge Measurement - 0 to 20mA Current Output Circuit
- Input and output circuit structure of MPD7500G c
- Input and output circuit structure of MPD7500Ga
- Joyoung JYC-22F electromagnetic cooker pulse width signal output circuit
- Differential input, double-ended output circuit
- High current output circuit diagram
- Light detection current output circuit
- Cold junction compensation isolated output thermocouple temperature measurement circuit
- Turbine flow meter analog output circuit
- Optical interrupter dual output circuit
