Bridge Measurement - 0 to 20mA Current Output Circuit
Source: InternetPublisher:smallembedded Keywords: Output circuit BSP Updated: 2021/03/26
RTD is a temperature measuring resistor, and the thermocouple ruler is used as cold junction compensation. They are
driven by the lrnA current source output by XTR101 as a constant current. When the RTD senses the temperature change, it causes the voltage between the ④ and ③ pins to change. This As the input signal
of XTR101 , XTR101 converts it into a 4~20mA current output.
The circuit shown in Figure 10-29 can convert the measurement signal of the bridge sensor into an O~20mA current output.
XTR101 converts the measurement signal of the bridge sensor into a 4~20mA current output, and the output current forms a voltage on Rj
; the operational amplifier OPA27 is connected as a voltage-to-current converter, and its inverting input (one) terminal and the output terminal are connected to 2 .SV
reference voltage source so that the voltage between them is constant 2. 5V. Therefore, the output current
, o=(1 +RI/R2), VR/RZ=1.251-5(mA),
when I=4~20mA, Io=O—20rnA.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Causes and solutions for noise in digital Class D amplifiers
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Important things to know about PCB routing and how to design the right routing for your PCB
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Touch circuit design and analysis
- Star finder battery indicator circuit
- Electronic thermometer circuit
- Electronic anti-asthma circuit
- Fish pond oxygenation reminder circuit
- Egg warming circuit
- Rural vegetable greenhouse lighting circuit
- Straw returning to field crusher circuit
- Domestic KD8041 integrated phase locked loop
- Series crystal oscillator
- color discrimination circuit
- Sine wave signal generator circuit
