ISO120-121 functional diagram
Source: InternetPublisher:念念Brown Keywords: RMS VR Updated: 2020/12/05
The IS0120/121 functional diagram is shown in Figure 10 J20. Isolation voltage: IS0120 is rated 1500Vrms; IS0121
is rated 3500Vrms. Nonlinear distortion: maximum ±0.ol%. High isolation : minimum 115dB (60Hz). Power supply
voltage: ±(4.5_18)V.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Which one is better, NPN or PNP transistor?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Tutorial on building a NOT gate using BJT transistors
- Experimental circuit based on 4040 binary adder counter
- Touch circuit design and analysis
- Experiment and production of NE555 time base integrated circuit
- An example of proportional integral circuit diagram
- ISO120-121 functional diagram
- 8-channel digital display temperature controller
- Ohmmeter circuit
- Principle and production of automotive power converter
- AD7982 differential conversion single-ended signal circuit diagram
- Working analysis of push-pull output
- DC converter output voltage
- Using VR to adjust bias voltage circuit diagram
- RMS sensor detection circuit
