DC converter output voltage
Source: InternetPublisher:傻阿乐 Keywords: Output voltage DC converter VR NDASH Updated: 2021/03/19
DC-DC converter output voltage is adjustable
Generally speaking, the output voltage of the DC-DC converter is fixed, like the picture above,
As long as a simple circuit is added to this diagram, the output voltage can be controlled through Vc.
Vout - Vr = (Vfb - Vr) (R1+R2)/R2
R1 = 20 kΩ and R2 = 10 kΩ
VOut – Vr = 3(Vfb – Vr)
VOut = 3 Vfb – 2 Vr(4)
Vr = 2 VR ef – VC
VOut = 3 Vfb – 4 VRef + 2 VC
3 Vfb = 4 VR e
VOut = 2VC
U1=0.8V, select R7=10 kΩ, R8=3.16 kΩ
Vref=0.6V
In this way, C1 reduces the output of U2 and ensures the stability of the U1 feedback loop.
- The basic principles of power supply design. What are the key components of a power supply?
- How about the boost converter TPS61299?
- Benefits of Wide Bandgap Technology for Power Converters
- 220V Remote Load Monitor
- Visible laser digital control modulation driver
- The constant current source composed of two transistors can drive high power
- Adjustable regulated power supply with current limiting protection
- An ultra-low output voltage regulator
- Power supply circuit that can reduce LM317 ripple
- 0.7~24V continuously adjustable current limiting power supply
- Typical Reference Voltage and Power Supply Circuits
- Oscillation process of multivibrator b
- The oscillation process of a multivibrator a
- Voltage stabilization control circuit in power circuit
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Additional power circuit design for USB devices
- Class A power amplifier power circuit
- Common power circuits and applications 09
- Common power circuits and applications 02
- Telephone power circuit
