LM84 digital temperature sensor
Source: InternetPublisher:李商隐身 Keywords: Digital temperature sensor BSP binary Updated: 2020/09/05
LM84 converts the temperature signal directly into a digital
signal, as shown in Figure 1-42. LM84 must be connected to an external
temperature sensing element V. V detects the overflow of the object being measured.
The analog signal generated by the temperature change is processed by LM 84
and outputs 8-bit binary data.
In the temperature range of 0-125cc,
binary data from 00000000 to 01111101 are output in sequence; in the temperature range of 0-55℃,
binary data from 11111111 to 11001001 are output in sequence.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- How are diodes made using semiconductors?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What does a rectifier do? What is the process of rectification?
- What are the types of commonly used batteries?
- Working principle/advantages/disadvantages/size of optical fiber
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to build a triangle wave generator using an op amp and discrete components
- LED Bicycle Lights
- An example of proportional integral circuit diagram
- stuttering correction circuit
- Bone hyperplasia treatment circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- Frequency modulator composed of NE566
- Voltage controlled power supply second-order high-pass filter circuit
- superheterodyne radio circuit
- Three primary color display circuit
