8 digital temperature control
Source: InternetPublisher:子丑寅卯 Keywords: Temperature control CNC BSP Updated: 2020/04/30
The 8-digit digital control is mainly composed of D/A converter, reference power supply, amplifier
, temperature sensor, etc. The circuit controls the temperature range from 0 to 5l°C and can be used for
intelligent temperature control of solar and other shower equipment .
The circuit divides 0-51qC into 28 =256 equal parts and changes it in steps of 0.2°C. IC4 is the reference voltage source, outputting 2.SV
voltage, which is added to the ICl~ pin through RP2 and R6 to provide the reference voltage to IC1. D/A converter IC1 accepts
8-bit digital signals from other digital output devices, converts them internally into analog signals and outputs them from pin ③. After the outputs of R2, RPi and AD590
are superimposed, they are sent to the operational amplifier IC3 for
amplification, and the analog signal vo is output. The function of the marrow
is to produce a certain hysteresis in the output voltage.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How does a series arrangement of Zener diodes affect the electrical behavior?
- How to read resistor color codes? Resistor color codes illustrated
- FPGA Features and Architecture
- What are the classifications of filters?
- Working principle and truth table of JK flip-flop
- Tutorial on building a NOT gate using BJT transistors
- What is the difference between JFET and MOSFET
- Digital number selection machine
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Biogas concentration detection line
- AC voltmeter
- Series crystal oscillator
- Schiller oscillator circuit
- Inductive feedback oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Three primary color display circuit
- Digital stopwatch display circuit
