TC649 motor overheating protection and drive circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Motor drive circuit overheating protection Updated: 2021/10/24
The motor is a heating device, which often causes the coil winding temperature to be too high due to accidents or overloads. Figure 1-9 shows
the TC649 motor overheating protection and drive circuit .
N TC thermistor RT is closely attached to the motor to detect the temperature of the motor. RT, ZI, and R2 determine the
input . The setting range is generally 1.2~2.6V. This voltage controls the output point of the output terminal K. The duty cycle of the PWM (Pulse
Width Modulation) signal (variation range is 0~100%). For example, at 30C, VIN = 1.9V, the duty cycle is
50qo; at 60qC, VIN = 2, 6V, the duty cycle is 100%; the PWM signal changes the speed of the motor after being driven by VT1.
Pin ⑤ is current detection, used to limit the size of the motor current. The current flowing through the motor or VT1 produces a voltage drop on R6
, which is fed back to pin ⑤ via c5 to control the maximum output current of the motor. ③Pin sets the threshold level for automatic shutdown.
With proper selection of VT1 and supply voltage, this circuit can drive a fan or a motor with a larger load .
- What is a photocoupler and how to select and use one?
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Analysis of the basic principle of measuring resistance by bridge method
- What are the types of commonly used batteries?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- How to calculate the value of capacitors in parallel?
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to install the accelerometer
- LED Bicycle Lights
- Motor inching control circuit
- Peanut and melon seeds roasting machine circuit
- Structure of air conditioner horizontal air deflector drive motor and circuit
- Autotransformer starts the main circuit of multiple motors
- Overload protection circuit for high-voltage motors
- Capacitor motor phase failure protection circuit
- Star connection motor phase failure protection circuit
- Application of motor drive circuit in automatic tracking car model
- Electronic stable speed motor application circuit
- Single-phase motor speed regulating circuit
