3 and 1/2 digit digital thermometer using PTC thermistor
Source: InternetPublisher:吃掉星星 Keywords: PTC digital thermometer thermistor BSP Updated: 2021/03/19
ICL7106/7107 is a dual-integrating A/D converter and 3-digit digital display driver. It is responsible for converting analog quantities into
digital signals. After further processing, it drives a 3.5-digit LED (ICL7106 drives LCD) digital tube to display the temperature data.
Character. ICL7106/7107 internally integrates oscillator, amplifier, comparator, counter, decoder, A/D converter
and other circuits. Use it to design a No. 3 digital display thermometer, which only requires a few peripheral components and is very simple to debug.
A 3÷-digit digital thermometer using PTC thermistor is shown in Figure 1-5.
The relationship between the numbers displayed by ICL7107 (lC2) and the input analog quantities is IV=IOOO Vl/VREF (IV is the
displayed number, vl is the input voltage, VREF is the reference input voltage), VREF=VREF HI- VREF L0 , in this example
VREF is set by RP2 (④ pin). In order to achieve the required accuracy and convenience of debugging, VREF is now set: lOOrriV (
determined by adjusting RP2 and RPl). At o°C, adjust RPi and RP2 to make vl(+)=273mV (corresponding to 273K =OC).
In this way, when the temperature increases by loc every time, the voltage change on RT is processed by ICL7107 and the temperature is displayed digitally.
OC1. OC3 is the oscillation pin, and the frequency generated by the oscillation (, =1/2. 2R3Cl) provides the internal clock signal.
REF HI and REF LO are the high and low inputs of the reference voltage respectively, which set the internal reference comparison potential; the @ and @ pins are the reference capacitors
; ⑤ and @ pins are the positive and negative analog inputs respectively, inputting the measured analog signal; ⑤-@ The pin is a buffer and integrating circuit
and is connected to R and C externally.
②. ⑧, ⑨~@, ⑤, ⑩~@, @ and ③ pins are the 7-segment signal output pins of the digital tube that drive units, tens and hundreds digits respectively
, driving the digital tube to display the measured temperature number.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- The Importance and Ideal Model of Impedance Matching
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the parts of the fpga design process
- How to calculate the value of capacitors in parallel?
- What is a D flip-flop and how does it work?
- Simple Wired Spy Bug Circuit Built Based on IC741
- What is the difference between JFET and MOSFET
- Introduction of TDA4863J/4863AJ TV field scanning IC
- A practical automatic electronic welcome circuit
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Physiotherapy ventilator circuit
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- Schiller oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Home appliance repair signal generator circuit
