Peak voltage sample and hold circuit
Source: InternetPublisher:已注销 Keywords: Voltage sampling sample and hold circuit LF398 LM311 Updated: 2020/08/05
Peak voltage sample and hold circuit : The peak voltage sample and hold circuit is shown in Figure 12-50. The peak voltage sampling and holding circuit consists of
a sampling and holding chip LF398 and a voltage comparator LM311 . The output voltage and input voltage of LF398
are compared through LM3J1 when U. >Uo hour. LM311 outputs high level and sends it to pin 8 of the logic control terminal of LF398, so that LF398 is in the sampling state.
When Ul reaches the peak value and decreases, U, <U. , the voltage comparator LM311 outputs a low level, and the logic control terminal of LF398 is set to a low level
, so that the LF398 is in a holding state. Since LM311 uses an open-collector output, a pull-up resistor needs to be connected.
The pulse sent from the output end of the overvoltage detection circuit controls the conduction of the circuit switch. When there is no overvoltage, the sampling capacitor is discharged. Otherwise, the sampling circuit keeps tracking
the changes in the peak value.
- Using Lead-acid Battery as Power Source for Walkman
- Step-down power supply for driving relays
- Basic circuit description of adjustable voltage regulator LM317
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- The constant current source composed of two transistors can drive high power
- Integrated regulated power supply with continuously adjustable output voltage
- CNC regulated power supply production
- Car power 1.5V-12V six-speed converter
- UC3842 Electric Vehicle Charger
- How to Select Modular EMI Filters for AC-DC Converters
- 24V power supply pure flat display high voltage power supply circuit diagram
- Output 12V-10A power supply circuit
- Timing switch AC power circuit
- Diamond differential input power amplifier power circuit
- Super Class A power amplifier power circuit
- Household emergency power circuit
- ±15V active servo power circuit
- 25Hz ring current power supply circuit
- AD conversion system using LF398 sample and hold device
- Basic application circuit for VF conversion using LM311
