Two-meter, two-watt FM phase-locked transmitter
Source: InternetPublisher:吃掉星星 Keywords: transmitter Updated: 2024/09/19
The circuit directly oscillates to an operating frequency of 144 to 148 MHz without a frequency multiplier. The oscillator is phase-locked to the crystal to ensure oscillator stability. In the 143 to 149 MHz tuning range, the corresponding varactor control voltage is 1 to 4 V, which maintains the appropriate loop gain over the full frequency band. The microphone preamplifier U5 is slightly overdriven, so the speech waveform is clipped or limited. The phase-locked circuit makes the frequency stability as good as the crystal used in the reference oscillator. Dividing the required signal frequency by 25 gives the crystal frequency.
- 76-110MHz band FM radio transmitter
- Inductorless FM transmitter
- Simple crystal frequency stabilized frequency modulation transmitter
- 5km FM transmitter
- 100W 2200m band transmitter amplifier
- Radio receiver circuit
- 6-watt FM transmitter amplifier
- 2km FM transmitter
- Circuit diagram of intercom made with LM386
- Radio active antenna
- 500m frequency modulation (FM) transmitter circuit diagram
- Transistor oscillation circuit for low power transmitter
- Automatic switch circuit diagram of TV sound transmitter
- "Electrical danger" language warning transmitter circuit
- Crystal controlled local oscillator for single sideband transmitter
- far field transmitter circuit
- 2m, 10W transmitter
- LED transmitter linearity control circuit
- Long distance serial communication circuit
- CAN bus communication circuit
京公网安备 11010802033920号
