Three-phase controllable rectifier circuit b
Source: InternetPublisher:三月小雨 Keywords: Rectifier circuit controlled rectifier trigger circuit BSP Updated: 2021/03/05
There are many forms of trigger circuit routing, such as some simple trigger circuits, single-junction transistor trigger circuits, sine wave synchronous trigger circuits, sawtooth
transition phase-shift (synchronous) trigger circuits, integrated trigger circuits, etc. Due to space limitations, this section can only give individual examples for introduction.
Brief introduction to the circuit principle: The trigger line outputs a sharp pulse to trigger the bidirectional thyristor to turn it on. The 220V single-phase power supply is phase-shifted through the capacitor and then
connected to the motor to make it run. Adjusting the 30W potentiometer changes the output pulse of the trigger circuit, thereby changing the conduction angle of VT1 and changing
the voltage on the stator winding, thereby achieving stepless speed regulation. This circuit can use two sets of trigger circuits to trigger two bidirectional thyristors to achieve
forward and reverse speed control of the motor.
Component parameter selection: Select 901, F/600V for the phase-shifting capacitor of the main circuit. Select 3CTS20A/800~1000V for VT1, select 10A for FU1 and FU2,
and select the rest according to the circuit diagram parameters.
- Step-down power supply for driving relays
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED rechargeable flashlight circuit diagram
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Dynamic power supply for power amplifier controlled by thyristor
- LM317 regulated power supply
- Smoking Cessation Circuit
- Agricultural temperature control circuit
- Rural vegetable greenhouse lighting circuit
- Double detuned loop frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Diode balanced amplitude modulation circuit
- Broadband high frequency power amplifier circuit
- superheterodyne radio circuit
- High and low frequency signal generator circuit
- Fault signal trip circuit
