half wave rectifier circuit
Source: InternetPublisher:偷熊计划 Keywords: Half-wave rectifier circuit BSP power transformer Updated: 2021/09/23
The structure of the half-wave rectifier circuit is shown in Figure a. In the figure, T is the power transformer , "." is the primary side AC voltage of the power transformer, P
is the secondary side AC voltage of the power transformer , rVD is the rectifier diode, L is the DC current
of the rectified output , Uo is the DC voltage of the rectified output,
R, . is the load of the rectifier circuit.
The input and output voltage waveforms of the half-wave rectifier circuit
are shown in Figure 12-lb, c.
In the positive half cycle of the ground, the diode VD is
forward-biased and conducts, and there is a current J. Through the diode and
the load , And a positive and negative pulsating DC voltage is generated at both ends of the load Ri. In the negative half cycle of №, the diode VD is reverse biased and cut off, no current
passes through the diode, and there is no output voltage at both ends of the load. The half-wave rectifier circuit only allows input AC The positive half cycle of the voltage ground passes through, and the rectified output is a half-wave pulsating DC voltage.
- Analysis of the working principle of switching regulator
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Step-down power supply for driving relays
- ISO113 circuit that can reduce power consumption
- Principles and precautions of active discharge circuit
- Adjustable regulated power supply with current limiting protection
- An ultra-low output voltage regulator
- UC3842 Electric Vehicle Charger
- Mc34063 MP3 Switching Charger
- Adjustable voltage regulated power supply circuit
- Motor overcurrent protection circuit
- strain sensor
- Ultrasonic blind pathfinder circuit
- Crop anti-frost circuit
- Agricultural spraying and insecticide control circuit
- Farmland drainage automatic control circuit
- Farmland irrigation automatic control circuit a
- base amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order active low-pass filter circuit
