Electronic volume control circuit
Source: InternetPublisher:zht24 Keywords: Volume Control Updated: 2024/09/14
TC9153 is a CMOS high-fidelity volume control dedicated integrated circuit launched by Toshiba. The circuit features low power consumption, current of about 1-3mA. Low distortion, THD≤0.005%. The volume attenuation range is 0--60dB, with 2dB as a step. The volume is controlled by buttons, which changes the shortcomings of traditional potentiometers such as short service life and high noise.
The circuit is shown in the figure above. The pre-stage signal is input from pins (3) and (14), and the controlled volume is output from pins (6) and (11). AN1 and AN2 are volume increase and decrease controls, and each press changes 2dB. After making it, it is best to shield the entire circuit to prevent noise interference.
Note: In this circuit diagram
A. Chip pins 2, 5, 12, and 15 should not be grounded
B. The 47K resistor should be smaller than the 33K resistor, because Rs is not less than 3 times Rx
- 36-hour watchdog timer
- Device control using dual-tone multi-frequency (DTMF) signals
- Electronic fuses for DC short circuit protection
- Full-function dual-path H-bridge
- 12V brushed motor speed controller
- Light-controlled/dark-controlled relay switch
- 9V Powered Xenon Flash Controller
- ACDC Power Supply Startup Considerations for PMDC Motor Loads (1)
- Brushless DC Motor Control Principle
- What is a soft starter? Soft starter working principle diagram
- Rural fish farming control circuit
- Pyroelectric automatic door control circuit
- Digital camera flash control circuit
- Chandelier control circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Neon light control circuit
- Range hood detection control circuit
- Taifu DK2-25 rice cooker temperature detection control circuit
- Control circuit of Gao Shida 25860T microwave oven turntable assembly
- Temperature measurement and control circuit
京公网安备 11010802033920号
