Hi-Fi 38W Class D amplifier circuit
Source: InternetPublisher:国民男神经 Keywords: Power amplifier circuit Updated: 2024/07/31
This class D amplifier uses the high-fidelity two-channel class D amplifier control integrated circuit LX1710 produced by MICrosEMI, and an external power field effect tube to form a BTL amplification. It can obtain 38W output power on a 2Ω load and the efficiency is about 84%.
The basic parameters of LXl710 are as follows: power supply voltage 7V-15V, output power per channel 25W (V=15V, 4Ω). At this time, THD+N=0.1, frequency response 10Hz~22kHz; when f=1kHz, output power 1W, THD+N=0.05; signal-to-noise ratio 81dB; switching frequency 335kHz; standby current 25μA.
LXl710 is equipped with noise filtering circuit, overcurrent protection circuit when load is short-circuited and static current reduction circuit, etc. The SLEEP terminal is in standby state at 0V and in working state at 2V.
The whole circuit is shown in the figure, with relatively few peripheral components.
The feedback signal is connected to the feedback amplifier in the chip through R3 and R4. Since the load impedance has a great influence on the characteristics of the output LC filter, the parameters of L and C should be adjusted according to the load. The parameters shown in the figure are when the load is 4Q. The actual test frequency response range is 5Hz~24.5kHz, -3dB.
This machine selects a low-threshold power field-effect tube. The Vcs of the tube model shown in the figure is 1.6V, and the on-resistance Rds (0n) = 0.019Ω.
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- The easy production of several top-quality tube preamplifiers
- Practical and high-performance preamplifier circuit
- Design and production of class AB headphone amplifier
- FU-7 Tube Amplifier Homemade
- Installation of electron tube differential amplifier circuit
- Inverting power amplifier circuit composed of LM4732
- LMl876 is used to assist the audio power amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- Application of BTL power amplifier circuit composed of LM3886
- 80W Class A and B power amplifier circuit
- F-9300 power amplifier circuit
- Linear feedback-free power amplifier circuit (b)
- 25W DC power amplifier circuit
- Homemade active subwoofer
- Power amplifier circuit with bass boost compensation
- Current feedback power amplifier circuit using LM1875
- Making LM1875 DC negative feedback BTL power amplifier circuit
- DC field effect power amplifier circuit using AP500A
- Current pouring power amplifier circuit
