Audio power amplifier circuit composed of AN7113S
Source: InternetPublisher:兰博 Keywords: Audio Power Amplifier Updated: 2024/09/10
AN7113S is an audio power amplifier circuit, which adopts 10-pin dual-in-line flat package, and the working power supply voltage range is 1.8~4.5V. The circuit has few external components, and its quiescent current can be adjusted according to different loads. This circuit is suitable for use as a power amplifier in low-voltage miniature radios or recorders. The maximum power supply voltage VCC of AN7113S is 4.5V, and the allowable power consumption PD is 360mW (T=25℃). The figure shows the typical application circuit of AN7113S.
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Telephone volume amplifier circuit
- 18-inch large speaker
- Design and production of NE5532+TDA1521 amplifier
- Make cheap speakers using waste circuit boards (TDA1013)
- Dual power supply audio power amplifier circuit using LM1875
- Audio power amplifier circuit powered by a single power supply using LM1875
- Dual power supply audio power amplifier circuit composed of LM3875
- LM4903/4905 differential input audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- Audio power amplifier circuit using MAX9789A and MAX9713 chips
- Auxiliary audio power amplifier circuit design based on LM4730
- 8W audio power amplifier circuit
- Two-channel high-fidelity power amplifier integrated circuit
- Audio power amplifier circuit using TDA8563Q chip
- Mono audio power amplifier circuit
- BTL audio power amplifier integrated circuit
- OTL audio power amplifier circuit
- 9W audio power amplifier (μPC2002) circuit diagram
- LM378 two-channel audio power amplifier circuit with adjustment circuit
