The circuit for increasing output voltage composed of precision logarithmic and logarithmic ratio amplifier LOG102
Source: InternetPublisher:柯南道尔 Keywords: Amplifier Updated: 2024/09/06
As shown in the figure, the circuit of increasing output voltage technology composed of LOG102 is shown. In many optical sensor detection applications, increasing output voltage technology is as important as increasing photodiode current function. The circuit in the figure uses a large reference voltage source to generate reference current, which reduces the error caused by LOG102 input offset voltage to a minimum. Reference current IREF flows into I1, and photodiode current IPHOTO flows into I2. When designing, IREF is greater than IPHOTO to meet the requirement. The role of internal amplifier A3 is to generate a level shift of inverting gain, which is used to calibrate the input photodiode current and the corresponding input A/D converter range.
- TDA1010 9W Power Amplifier
- 12V lamp current indicator
- Battery-powered amplifier
- Introduction to Photosensitive Devices
- Diode and gate circuit schematic diagram and principle analysis
- How to correctly start the transistor
- How to Build a TIA Circuit Using a Fully Differential Amplifier
- Correcting DC Errors in High-Speed Amplifier Circuits
- RC voltage reduction principle and calculation formula
- How to understand operational amplifiers in a simple and easy way
- Take stock of wonderful designs
- simple audio mixer
- High-precision low-noise filter circuit design
- Clamp amplifier circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- LTC2053 thermocouple amplification circuit diagram
- Parallel power op amp
- Operational transconductance amplifier with booster
- Multistage amplifier circuit fault analysis
- OTL low frequency power amplifier circuit
京公网安备 11010802033920号
