Mechanical electric shock switch value conversion circuit a
Source: InternetPublisher:MartinFowler Keywords: switch conversion circuit contact Updated: 2020/10/07
It is a conversion circuit for mechanical contact switching. The switch conversion circuit with its own power supply in the control system is generally used in situations where the switch is installed close to
the computer control device. The power supply is DC 24V or less. Commonly used circuits have two forms: series and parallel . For parallel circuits
, when the contacts are closed The output % is high level, and Vo is low level when the contact is open. A series circuit is just the opposite. The external power supply switch value conversion
switch is suitable for situations where the switch is installed far away from the control device. When a conversion circuit in the form of a DC power supply is used , the two transistors are protective
components, and the power factor should be considered in the selection.
- What does a rectifier do? What is the process of rectification?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- The Importance and Ideal Model of Impedance Matching
- What are the classifications of filters?
- What is the difference between CPLD and FPGA?
- Datasheet/Pinout/Technical Specifications of LMC555
- Ceramic filter structure/working principle/characteristics/application
- How to install the accelerometer
- What is a Demultiplexer
- Circuit diagram of an example of differential and integral circuits
- Improved single-stage PFC conversion circuit diagram
- Celsius temperature conversion circuit diagram for thermometer
- Transformation circuit diagram
- Use 555 to form a DC step-down conversion circuit diagram
- 555 DC boost conversion circuit diagram
- DC/DC conversion circuit diagram without isolation
- Voltage doubling conversion circuit diagram 2
- Voltage doubling conversion circuit diagram 1
- MAX608 buck-boost conversion circuit diagram
- Differential input voltage-current conversion circuit 1
