LED backlight driver module circuit diagram
Source: InternetPublisher:抄写员 Keywords: LED backlight circuit diagram driver module module circuit Updated: 2021/08/17
Circuit analysis: The requirement of the backlight driver is that the brightness of the backlight LED remains unchanged under any conditions, that is, a constant current source circuit needs to be constructed. The backlight drive circuit shown in the figure is the simplest constant current source circuit. When the circuit is working, the voltage across resistor R9 is equal to VLL1 plus the BE conduction voltage, which is a fixed voltage of about 1.7V. The current flowing through R9 is also fixed. The current is approximately equal to the emitter current and collector current of Q2, so the current flowing through the backlight diode D1 is also a constant current, realizing the constant current drive of the backlight LED. The driving current of the backlight LED is about 10mA, and the value of R9 is 150Ω.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Using Lead-acid Battery as Power Source for Walkman
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Introduction and principle analysis of switching regulated power supply
- What kind of circuit is a voltage regulator circuit?
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- Dual forward converter schematic diagram
- Laser power circuit
- LED backlight driver module circuit diagram
- Output 12V-10A power supply circuit
- audio power circuit
- Music power circuit
- Power circuit for home appliance repair
- Neon light high voltage power supply circuit
- Rectifier module circuit diagram composed of DZW75-48/50 (50II) type
- 3 to 30V universal power module circuit
- Ultra-small DC-DC switching power supply module circuit
