Bidirectional line driver circuit composed of OPA2662
Source: InternetPublisher:抄写员 Keywords: Drive circuit Updated: 2023/12/14
As shown in the figure is a bidirectional line driver circuit composed of OPA2662. This circuit uses the internal dual-channel OTA of OPA2662 to form two channel current output driver circuits, one of which is used as a transmitting driver and the other as a receiving driver. The switching between transmitting and receiving is controlled by the enable terminal EN. When pin 3 (EN1) is high level (pin 6 EN2 is low level at this time), the circuit is in the receiving state, the input signal enters pin 2 through the cable, and is output by pin 14 after amplification; when pin 6 is high level When the signal is flat (3-pin EN1 is low level at this time), the circuit is in the sending state, and the input signal enters pin 7 through the cable, and is output from pin 11 after amplification.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- How to identify common mode interference? Methods to eliminate common mode interference
- Working principle and truth table of JK flip-flop
- Diode-based clipping circuit
- What types of force sensors are there?
- Experimental circuit based on 4040 binary adder counter
- Make a simple AM radio with digital circuit
- Star finder battery indicator circuit
- Experiment and production of NE555 time base integrated circuit
- Hard drive motor drive circuit
- Driving circuit diagram
- DC brush motor drive circuit schematic diagram
- Motor drive circuit for stable speed control using negative feedback method
- XJ01-80 to 300 type auto-coupling step-down starter drive circuit
- High performance DC power amplifier drive circuit AP500A-02
- LM621 brushless DC motor commutation circuit-three-phase full-wave drive circuit
- DC motor drive circuit
- Industrial four-way programmable controller drive circuit
- Smart car drive circuit
