Bi-phase clock signal generation circuit
Source: InternetPublisher:ohahaha Keywords: clock signal signal generation Updated: 2021/12/10
Shown is the phase clock signal generation circuit. The circuit uses the NE555 actual circuit as the core to form an oscillator. It can generate
complementary interleaved bi-phase clock pulses required by most bi-phase dynamic MOS memories and shift registers. The pulse duty cycle depends on the resistance
of the external resistors Ri and R2 . The oscillation frequency depends on the resistance values of Ri and R2 and the value of the timing circuit C. The SN7473 flip-flop is used to determine which
phase is gated by the SN7402 NOR gate. The maximum operating frequency of this circuit is l MHz.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- How to read resistor color codes? Resistor color codes illustrated
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What is a D flip-flop and how does it work?
- Share an interesting LED decoration project
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- What is a Demultiplexer
- Touch circuit design and analysis
- Circuit structure and symbols of synchronous RS flip-flop
- Pulse signal generating circuit b
- Photoelectric motor speed signal generation circuit
- Pulse monitoring signal generation circuit composed of monostable trigger
- Sawtooth wave circuit and signal waveform in field scanning circuit
- Single pulse signal generating circuit g
- Single pulse signal generating circuit e
- Single pulse signal generating circuit d
- USB signal generation circuit
- DSB signal generation circuit
