Delay circuit with fixed frequency division factor
Source: InternetPublisher:清宁时光 Keywords: Delay Circuit Updated: 2024/08/28
The figure shows a delay circuit with a fixed frequency division coefficient. The circuit is composed of a 60-frequency divider 74LS57 and a D flip-flop 7474. The 74LS57 has an independent 6-frequency divider and a 10-frequency divider cascaded by a 5-frequency divider and a 2-frequency divider, and its output terminals are QA, QB and QC respectively.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What are the parts of the fpga design process
- Datasheet/Pinout/Technical Specifications of LMC555
- Beautiful crown wreath made with LED
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Make a simple AM radio with digital circuit
- Simple LED advertising light circuit
- Delay circuit using operational amplifier
- Thyristor cut-off delay circuit 3
- M69032P application circuit
- Human body infrared detection alarm
- Simple power-on delay trigger circuit
- pulse delay circuit
- Power frequency 0-5 minute delay circuit diagram
- Automatic conversion using transistor delay circuit
- Long delay circuit with wide adjustable range
- Switch off long delay circuit diagram
