Delay circuit using operational amplifier
Source: InternetPublisher:蓝猫淘气 Keywords: Delay circuit operational amplifier timer comparator Updated: 2020/01/17
It uses operational amplifier A as a comparator and has high timing accuracy. The timing range of this timer
is 1~30s.
The delay time is determined by Ri, RP and C. By adjusting RP, the delay time can be changed.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to build a simple tachometer using an infrared reflectance sensor
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Add one more component to improve the phase failure protection function
- Design and principle analysis of practical electric curtain remote control device
- Infrared blocking alarm device
- Delay switch made with LM431
- Ultra-short wave item left behind reminder alarm
- Phase locked loop integrated circuit timer
- One-digit display timer circuit diagram
- One of the long delay circuits using integrated circuits
- One of the conductive tube controlled charging short delay circuits
- Lighting delay circuit using single-junction transistor Part 2a
- sequential timing circuit
- Continuous timing circuit diagram for delayed monostable multivibrator
- Timer alarm circuit diagram for car or room
- Precision timer (2) circuit diagram
- Long timer that works on mains power
