Electronically tuned FM radio circuit
Source: InternetPublisher:消失的歌 Keywords: FM radio resonant circuit Updated: 2020/05/27
Shown is an electronically tuned FM radio circuit. A varactor diode (1SV75) (as a variable capacitor) is used in both the high-frequency resonant circuit
and the local resonant circuit
. When tuning and selecting a station, 3 to 9 values are sent from the tuning circuit. V DC voltage is added to the load of each varactor diode
to provide reverse bias for the varactor diode. The varactor diode and its parallel coil form a resonant circuit. The
high-frequency FM signal induced by the antenna is added to the commercial frequency resonant circuit Li. On the first gate of the high-frequency amplification field effect transistor VT1,
the output of VT1 is sent to the base of the mixing transistor VT2 through the transformer and the high-frequency resonant circuit b. It is composed of VT3, coil L3 and capacitor (including
the capacitance of the varactor diode) It forms a local oscillation circuit . The oscillation signal is sent from the emitter of VT3 to the base of mixer VT2 through the 8'pF capacitor.
After the radio frequency signal and the local oscillator signal are mixed in rr2, they are output by the collector of VT2. Then the intermediate frequency signal is selected through the medium-rated transformer and then output.
- Change the Zhongjiu receiver to 12V power supply
- Energy-saving and environmentally friendly bicycle speakers
- AM FM IF amplifier integrated circuit LA1201
- Galanz WP700 mechanical microwave oven circuit diagram
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- AV switch made with decoder
- Electric curtain circuit a Household appliance circuit
- Electronic disinfection cabinet circuit
- Use LB1405 LB1415 as volume meter application circuit
- AM radio automatic search and trigger circuit
- Small FM radio circuit
- FM intermediate frequency amplifier circuit
- Electronically tuned FM radio circuit
- High frequency voltage controlled oscillation circuit
- FM radio circuit of DA-101 chip
- MP3 FM radio circuit
- AM-FM radio circuit
- Application of field effect transistors in pocket radio circuits
- Ultrasonic resonance circuit
- Standard crystal oscillator circuit with resonant circuit
