Interface circuit based on 8155 and single chip microcomputer
Source: InternetPublisher:ghaytweyhtoo Keywords: MCU interface circuit Updated: 2024/07/19
The interface circuit composed of 8155 and single-chip microcomputer is shown in the figure below.
According to the wiring diagram in the figure, assuming that A14~A9 are all high level, 8155 will work, so there will be:
Memory address: 0x7F00~0x7FFF.
Command/Status Register Address: 0x7E00 (There are 32 corresponding addresses, select a valid address).
Port A address: 0x7EO1 (There are 32 corresponding addresses, select a valid address in the period).
Port B address: 0x7E02 (There are 32 corresponding addresses, select a valid address in the period).
Port C address: 0x7E03 (There are 32 corresponding addresses, select a valid address in the period).
Timer register A address: 0x7E04 (there are 32 corresponding addresses, select a valid address).
Timer register B address: 0x7E05 (there are 32 corresponding addresses, select a valid address).
- Circuit diagram of multifunctional digital clock
- Interface circuit between intelligent temperature sensor TCN75 with two-wire serial interface and 89C51 single-chip microcomputer
- Interface circuit between AT89C51 and RS-232
- FPGA and DAC0832 interface circuit
- Ultrasonic anti-theft alarm designed based on microcontroller and HC-SR04
- How to use ESP8266 to design a portable air quality monitoring station
- Improvement of microcontroller-driven piezoelectric buzzer
- Circuit diagram: 8051
- A safe and reliable IC card reader/writer system circuit
- Microcontroller test board circuit 1
- CNC machine tool and computer communication circuit diagram design
- Analysis of internal reset circuit diagram of microcontroller
- Dual audio decoding electronic circuit
- Stepper motor drive circuit composed of LB1836M
- Two types of negative voltage generation circuit diagrams of single-chip microcomputer
- Minimum system interface circuit based on AT89C52 microcontroller
- Keyboard-display interface circuit
- Contact relay output control interface circuit
- Switching interface circuit in timing query mode
- Optoelectronic interface circuit between single-channel DA chip DAC0832 and microcontroller
