Three-phase three-wire active energy meter direct connection circuit
Source: InternetPublisher:柯南道尔 Keywords: Wiring energy meter three-phase three-wire Updated: 2020/03/20
Requirements for direct wiring of three-phase active energy meters.
1) Before wiring, check the model, specification and load rated parameters of the electric energy meter. The rated voltage of the electric energy meter should be consistent with the power supply voltage. The rated current should
not be less than the load current, and the appearance of the meter should be intact.
2) The wires connected to the electric energy meter must use copper-core insulated wires. The cross-sectional area of the wires meets the mechanical strength
requirements . The cross-sectional area of the voltage return wires is not less than 1. 5mmZ. For the current loop wires The cross-sectional area should not be less than 2. 5mmz.
The conductors with a cross-sectional area of 6mmz and below should use single-strand wires. There should be no joints in the conductors.
3) The polarity must be connected correctly. The first end of the voltage coil should be connected to the phase line together with the first end of the current wire. The neutral line of the blue phase four-wire must go in and out of the energy
meter.
4) Wiring must be in positive phase sequence, and the switch and fuse
should be connected to the load side of the energy meter.
Wiring circuit ; three-phase three-wire active energy meter plug-
in wiring is shown in the figure. This figure shows the
direct connection method of DS type 5-10A three-phase three-wire active energy meter . For three-phase three-wire
above 10A , the internal wiring is different, but
the external wiring is basically the same.
- How about the boost converter TPS61299?
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Step-down power supply for driving relays
- Op amp power supply decoupling bypass measures
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Dual forward converter schematic diagram
- A simple positive and negative power supply circuit
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- BX2-700, 1000, 2000 arc welding machine remote control circuit wiring
- Connection between PLC and frequency converterb
- Isolation transformer and low pass filter wiring a
- Lightning protection wiring c for direct distribution generators from 300 to 1500kW
- Y, y connected transformer lightning protection wiring
- Wiring of lightning protection belts, voltage equalizing rings, etc. in high-rise buildings
- Wiring d when leakage protector supplies power to single-phase load in TN system
- DX2 type three-phase three-wire reactive energy meter is connected to the circuit through a current and voltage transformer
- Three-phase three-wire DX2 type reactive energy meter with 60° phase difference is directly connected to the circuit
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
