Machine tool lighting short circuit protection circuit
Source: InternetPublisher:三月小雨 Keywords: Machine tools short circuit protection circuits transformers Updated: 2020/04/30
In machine tool lighting, a mobile 36V transformer lighting power supply is generally used. During use, short circuits often occur and burn out fuses
, transformers, etc. If a relay is used as the switch of the transformer,
the above situation can be avoided.
The circuit is shown in the figure. Turn on the switch S and press SB1, the secondary
side of the transformer outputs 36V, causing the relay KA to close. When a short-circuit fault occurs in the lighting circuit transformer
, the voltage of the relay coil is zero, KA is powered off and released, and the lighting circuit
is protected.
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- A small improvement on the ordinary refrigerator motor starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Motor control circuit for starting and running without phase loss
- Design and production of radio remote control fan stepless speed regulator
- Delay switch made with LM431
- Homemade short circuit alarm device
- Precious home appliance anti-theft alarm
- Full wave and bridge rectifier circuita
- Bidirectional frequency conversion circuit
- FM radio tuning circuit
- Transformer AC contactor DC operation circuit c
- Transformer cooling fan automatic control circuit
- Lightning protection wiring of oil switch on pole a
- Commonly used non-sinusoidal oscillator circuits, waveforms and frequency calculation formulas - pulse wave oscillator - transformer intermittent oscillator
- Rectifier circuit with central axis transformer output bipolar voltage b
- Rectifier circuit a for bipolar voltage output from a double-winding transformer
- The synchronous voltage is taken out from the secondary side of the two-phase transformer
