Water inlet motor protection circuit
Source: InternetPublisher:风向西瓜 Keywords: protection circuit motor protection motor relay Updated: 2020/05/16
Use a relay to protect the circuit of a water-immersed motor as shown in the figure. When the commercial button SB2 is pressed, KM is powered and self-suppressed, and the motor M starts
to run. If water enters the motor at this time and submerges the probe A. Through the water, A is connected to the casing, relay K is closed, and the normally closed contact
is disconnected. KM is released when power is lost, and motor M stops. At the same time, HA sounds the alarm.
- How to choose the right level of integration to meet motor design requirements?
- Model rocket launch controller circuit
- Design of an autonomous plant watering system using ATtiny85
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Perform surgery on the speaker protection circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor control circuit for starting and running without phase loss
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of the principle of automatic power-off switch during power outage
- Water supply reminder after water outage
- Relay inverse time overcurrent protection circuit a
- Low voltage circuit breaker protection circuit e
- Thyristor resistance-capacitance protection circuit a
- The structure and working principle diagram of various protection circuits f
- Series regulated power supply circuit protection circuit 2
- Thyristor overcurrent protection circuit one a
- One of the mains undervoltage and overvoltage protection circuits
- Three-phase AC power supply phase sequence protection circuit
- Small hydropower station motor speed regulation and overrun protection circuit
- Asynchronous generator capacitor overvoltage protection circuit
